I created a surface (many actually) now I want to put a circular hole (several of different sizes to be accurate) in the surface. Neither make a hole or boolean operations seem to cut a surface. I tried converting the surface to a mesh and using a mesh sphere as the boolean cutter- no luck. I tried converting the surface to a nurbs object with SrfPrt- nothing.
The surfaces were created from 2 curves using the EdgeSrf command.
How can I punch circular holes in them?
