I am working on a small project for a few tiled patterns .
I do this by drawing a grid of lines in both X and Y directions at one centimeter distance. I then select the lines and use curve boolean to visually “draw” the shapes I like to keep.
The workflow works perfectly for what I am trying to do, however is pretty slow.
Curve boolean forces me to click select one shape at a time, when I am doing hundreds per panel, it does become slow.
I was wondering if anyone has some advice on how to improve the workflow? It would be great to be able to use a “brush” ish behaviour to click and drag over the surface to select several parts
I like the responsiveness of the method and dont really want to do any image based ones unless there is a realtime link aspect to it.
Thank you for your help
