Help! Organizing UV Structure for "Surface Creation" from Curve Endpoints
**Help needed!
Hi, I’m working on my school project
I’m trying to create a surface from the endpoints of several curves that lie on a base surface.**
I tried using Loft and Network Surface, but I’m having trouble generating the necessary polylines. I want the endpoints to form an organized U and V structure, but I couldn’t manage to get a clean UV order.
I tested the workflow on a simple square base surface, and it worked correctly. However, when I switch to an irregular base shape, the UV count becomes disorganized and I’m unable to produce clean polylines for a loft or network surface.
I’m leaving my grasshopper script and rhino file.
1.12.25 question.3dm (3.2 MB) -Base surface is the blue colored layer (name-project surface)
1.12.25 Question.gh (34.9 KB)
Does anyone have suggestions for keeping the U/V structure consistent when working with non-rectangular base surfaces?
I would be very, very grateful for any help and any kind of guidence!!
Thanks a lot in advance!
