Vasanth_C
(Vasanth C)
1
Hello guys, there is a solid intersection help required here
What sort of data flow is required in order to achieve what I seek,
There are to fins which are to be generated from the BREP surface which I have to dissect
Internalized the curves and any help would be much appreciated, attaching the script below
fins construction.gh (23.2 KB)
Thank you:)
You need to flatten the input for the 4 surfaces to join into one closed brep.
Then the 60 rectangles aren’t extruded so the boolean difference does not work.
Here’s one way to do it:
fins construction.gh (37.5 KB)
Vasanth_C
(Vasanth C)
3
Thank you for your kind support @martinsiegrist
Many Thanks for the input!!
