I have been trying for days to make this surface cleaner and am out of ideas… was hoping someone would be able to see a better approach. Currently I have made 3 x network surface, having created cross sections joining areas A and B, with blend curve to G2 continuity. I have made these limit curves degree 5.
This will never work. Bad curves. Gaps. No G1 or G2 continuity between surfaces. Also, the original curves used to build this part of (?) are not there.
I would first work out a suitable patch layout, draw simple single-span curves for the surface boundaries, and then stay away from NetworkSrf as far as possible. It’s known as notwork surface for a good reason.
A, B, and C can be built as EdgeSrf, and then you will inevitably have a crease towards the back of that thing, because of the G0 corner.
