I need help understanding on how a brep could be cut in grasshopper. I have attached the file and image under for your reference. The idea is to cut the vertical member exactly under the horizontal member and since the width is differnt I want to taper it . Also once it is cut I want to close it off with a similar thickness of a surface on a flat surface so it looks clean from outside. Thanks!
