Hello everyone, I am acquainted with Rhino, however I cannot seem to fix this issue. I am trying to ‘clean’ up the model from the many surfaces, MergeAllCoplanarFaces function doesn’t help, doing Patch is also time consuming, and some grasshopper components don’t exactly help. I want to know whether there’s a simpler way to speed up the process of this model. I’d appreciate any help.
Upload a .3dm file with a small portion of the model. (Let us know if you need help with how to split off and export a portion of the model.) It is difficult to impossible to provide assistance based on images. You can upload the file by dragging it to where you type a post, or by clicking on the vertical arrow icon above where you type a post.
Was this model created using Rhino, or using other software?
Is this a mesh model, a NURBS model, or a SubD model?
If it is NURBS model was it originally a mesh model or a SubD model?
How much experience do you have using Rhino?
How much experience do you have with other CAD/3D software?
What exactly do you mean by “smoothing”?
Reverse Engineering likely
_AddNgon does a kind of magic of hiding the edges of coplanar triangles.
Be sure to have the vertex welded ( _weldvertex with angle around 20 or 30).
Both are just to clean the meshes then tonubr gives you the corresponding nurbs faces. Works very well for flat part, rounded one need to be manually reconstructed.
Another option could be use _Shrinkwrap, ideal for prototyping.
Normally, inexperienced users mean “G1/G2 surface transitions” or “reducing triangle mesh noise”, or something along those lines when using “smoothing”, but what do I know.
Yeah, I suppose it could be as simple as converting to quads or ngons. “Smooth” is definitely ambiguous.
