Hello there,
I would like some help with a Grasshopper definition or c#/python node to achieve the result like in the image bellow:
What I want to input:
- Curve
- Start point on curve
- the rectangles (can be more or less)
- the arrangement of rectangles like (1,4,4,3,3,3,5,5,5)
- The X distance fixed for all placements
Any help will be much appreciated!
I think this is feasible without too much work, except for that X dimension. Does it need to be exactly the minimum distance between rectangles ? Or corner to corner distance (not the minimum distance, see the space between your rectangles 2 and 3) ? Or could it be a higher value defined along the curve, sufficiently high to ensure the distance X is bigger that your target ?
Yep the X value should be a defined minimum corner to corner distance… can be higher than the minimum but not to much.
I would have liked it to be a fixed value That’s the ideal situation
C# for the win !
RectanglesOnCurve.gh (30.3 KB)
