Help Needed - Inserted Link Missing in BlockManager
Hi all,
I’m having an issue with inserting a .dwg as an active link.
The link only appears in the Block Manager when inserted as a block, is there any way to update a linked file inserted as a Group or as Individual Objects? Block insert isn’t giving me the control I need to select individual layers within the file.
Appreciate any help!
no, linked files are not editable in the file they are inserted in. But if you set up the source file correctly with its own layer structure, you could show/hide parts of the linked file.
