Currently trying to model the curved surface of a roof with known geometries from its elevations.
Essentially a rectangle in plan, with each elevation being a parabolic curve. I want to ‘loft’ these four elevation curves, forming a single seamless curved form. Any pointers on how to achieve this would be greatly appreciate. Thank you!
Hi @Hans_H
Welcome In this case, the easiest way is to join up your curves, so that you have a “3x3 grid” with 3 spans in each direction - and then use NetworkSrf to create the surface.
