Help modeling a building
Hi
I need to module the Jewel Changhi Airport, by Safdie Architects I need to create a detailed construction of the sphere.
I would greatly appreciate any help with the process using Rhino and Grasshopper if needed.
I don’t know where to start.
Thank you so much in advance.
You have to start bleeding to understand the concept of the rhino. Avoid studying grasshoppers if you don’t fully understand how to use the rhino part by part. Rhino first from zero to hero. and then started studying grasshoppers. Sorry, it’s difficult to answer your question above, because it requires a lot of time. The solution is that you have to understand the concept of the rhinoceros and you can do anything. from donuts to spaceships.
