Help me animate a v-8 curtiss ox-5 please!
I’ve been using rhino since v1 but i cant seem to figure out bongo. i’m building a curtiss ox-5 engine and i have most of it done, id like to animate it. i would be grateful to anyone who could animate this model and explain how they did it.
jenny engine.3dm (18.4 MB)
Hi Jon,
I animated 1 piston in your model. The rest is up to you.
jenny engine 001.3dm (19.0 MB)
The “crankshaft” is keyframed to rotate 360°.
The pivot of its child “rod” is moved to the position of its junction with the crankshaft. It is made a IK-joint, Hinge, X‑axis.
“spindle” a child of “rod” kind of ends the basic IK-chain. “spindle” is allowed to rotate with respect to “rod” – hence it’s a joint, hinge, X-axis – and it is also constrained to “track” (the center line of the absent cylinder) to make it move in the correct direction.
“piston” a child of “spindle” also is constrained to “track” to keep it in the same correct direction.
Both constraints are necessary because Bongo’s constraints operate on the origin of object’s pivot which is a point. In order to define a line one needs 2 points (at least).
Allow me to recommend a viewing of my video Whys of IK in Bongo 2.0 - YouTube
Luc
BTW there is a sample model of a piston engine on Rhino - Sample Models
thank u luc
i guess im a compllete idoit, ive spent hours trying to get the next pisston to work. do i need to create an entire new ik chain? and it wont let me constrain to a track, idny
Jon,
Do not despare. Take a look at the Animation Manager in the sample model mentioned above (at Rhino - Sample Models)
There are 4 IK branches that share the same ‘driving head’, namely the object “cranshaft”. Each branch ends in its own constraint.
For your V8 engine you obviously need 8 branches.
As for establishing the constraint, I guess you’re puzzled because the option “Constraint to object” appears grayed-out.
You simply have to click the ‘Select target object’ button to get going. I agree it’s a bit confusing.
Have an other try. When the hours or the patience to spent run out I can do it for you. Just give me a sign.
Luc
