@everybody,How can two objects intersect when there are so many objects?
Using intersction class, the calculation is large and inefficient
Shift + select the objects you want to make the intersection with and use the ‘intersect’ command.
You can also first isolate the objects you want to intersect: Hide all but selected..what command?
