Why do you need it to be a closed polysurface?
If it is just for rendering, you could try loosening your file absolute tolerance in file>settings. I haven’t checked the gaps between the surfaces though.
Also the hole you had in the bottom surface I didn’t place back.
okay i placed the hole back in the bottom and it is now a closed polysurface! thank you so much mate! i owe you one! let me know if i can help you in anyway! in keyshot i am good! and fusion 360!
a t or a w makes all of a difference.
sorry just corrected my typo! now a closed polysurface
To start with, the patch layout could use a lot of improvement - you have a surface seam across the “apex” of the blend, you should have seams at the start and end of the blend (the two upper lines I’ve added):
There should also be a break where the straight section in side view ends - the lower line I added.
thank you so much @sgreenawalt for your valuable feedback and contributing to the community’s knowledge pool!
