Help:How to cull index base on conditions
Hi friends,
How to cull there buranch on condition: once the second number of these branch index is the same as the last one ? See picture below.
question of cull.gh (11.3 KB)
Can you post a file?
One way
But do share the file
I have a solution, not the most elegant but works, and does not depend on any culling pattern:
I inverted the pattern to show the results:
Nice solution. If you want a simpler one, just check for equality of branch indices → creates cull pattern → done
Edit: Which is exactly what you’ve done
This would work, for sure, only for symmetric tree. If you have something pre-culled and missing some tree element then, I guess, it won’t work.
I’ll have to test it, but no reason comes to mind why it wouldn’t work.
By the way, you’re using cull pattern successfully in your scrpt…
Sure thing, I misunderstood you at first.
I am sorry for I foegot to upload the gh file. And now I have just uploaded it.
Great! I will give a try immediately. Thanks.
This is your tailored solution:
That’s why it is always worth posting sample files.
Don’t forget to invert the culling pattern.
With your help, I get it finally!
Thanks again !
