help for (offsets BreMergeCoplanarFaces)
offsetbrep+Mergecoplaner srf.gh (13.7 KB)
private void RunScript(Brep X, double distance, bool solid, bool round, bool Merge, ref object A, ref object B, ref object C, ref object brep, ref object Result )
Brep[] blends;
Brep[] walls;
Brep Brep;
Brep = X;
if (null != X){
Brep[] offset = Brep.CreateOffsetBrep(Brep, distance, solid, round, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance, out blends, out walls);
if(Merge == true){
brep = offset.MergeCoplanarFaces(RhinoDocument.ModelAbsoluteTolerance);
Result = brep;
brep = offset;}
A = blends;
B = walls;
C = offset;}
@Mahdiyar
dale
(Dale Fugier)
2
Your offset
variable is an array, not a Brep
Maybe something like this:
Brep[] offset = Brep.CreateOffsetBrep...
if (null != offset && offset.Length > 0)
brep = offset[0].MergeCoplanarFaces...
ā Dale
thanks
With your tips I managed to write this code
private void RunScript(Brep Polysrf, double distance, bool solid, bool round, bool Bothside, bool MergeAllFace, ref object A, ref object B, ref object brep, ref object Result )
Brep[] blends = null;
Brep[] walls = null;
Brep[] b;
if (null != Polysrf ){
if (false != Bothside ){
b = offset(Polysrf, distance * (-1), false, round, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance, blends, walls);
b = offset(b[0], distance * (2), true, round, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance, blends, walls);
brep = b;}
else
b = offset(Polysrf, distance, solid, round, Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance, blends, walls);
brep = b;}
if(MergeAllFace == true )
{ brep = b[0].MergeCoplanarFaces(Rhino.RhinoDoc.ActiveDoc.ModelAbsoluteTolerance);
Result = brep;
brep = b[0];
A = blends;
B = walls;}
// <Custom additional code>
Brep[] offset(Brep B, double d, bool s, bool r, double tol, Brep[] ble, Brep[] wa)
{return Brep.CreateOffsetBrep(B, d, s, r, tol, out ble, out wa);}
