HELP: fillet concave geometry edges
Hello everyone,
I have a tile with quite complex, concave surface. Given that the edge is quite sharp, we need to fillet the edges- but I have reached the limit of my capabilities in Rhino at this point.. Can someone help out with that please?
The surfaces are meshescause itwasthe only way I could maintain edge straight. I know they do not align perfectly, but I could not solve that either..
I will gladly share the fie, too, if someone has any ideas to test
Thanks for any suggestions!!
Welcom @ATTA to to forum :slight_smile:
Please share a 3dm file and it looks like you’re using Grasshopper? If so, share the grasshopper script too.
tile design.3dm (1.5 MB)
Here is the 3dm file :slight_smile: I did not use grasshopper to create surfaces
It is not possible to fillet meshes or surface/mesh boundaries. You need to approach this differently. I will try to come up with an alternative, but please keep trying yourself as well :slight_smile:
What size fillet do you intend to make? —-Mark
Hello @markintheozarks, about 3mm radius
(1) my first thoughts…
i fiddled around with some planar mesh and quadremesh with guide curves.
no success with it.
(2) more work but more reliable:
the target should be a nice subd typology.
so my suggestion would be:
set up a very basic planar typology using _3dFace quads.
This typology must represent the cells.
_subdivide and finetune
_project the inner surface points to the reference mesh
use _crease at the beginning.
(A) finally do some fake fillet with _bevel or _creaseSubDEdge
(B) convert to Nurbs and do some filleting (with some pain and limitations)
i only worked on 4 of the cells to show the concept… did not fiddled it to the end.
also: Rhino 9 offers “_inflateCrv” but this command those not respect the neighbouring edge.
(you will end up with similar problems as you already have: non matching Edge-Vertex numbers)
what is the usage for the final data ?
good luck (still some work) and happy modelling - tom
