Hi guys, I am struggeling with a slow image manipluation as reading and writing each pixel take a long time.
This script gets the viewport image and sets all RED values to 255, but it takes like 5 seconds to recalculate a 1000x500 pixel viewport.
import scriptcontext
import System
# Capture the active view to a System.Drawing.Bitmap
bitmap = scriptcontext.doc.Views.ActiveView.CaptureToBitmap()
### --- modify bitmap
### --- make new bitmap
format = System.Drawing.Imaging.PixelFormat.Format32bppRgb
Width= bitmap.Size.Width
Height=bitmap.Size.Height
print Width,str("x"),Height, str("pixels. Total = "), Width*Height
bitmapNew = System.Drawing.Bitmap(Width, Height, format)
for iW in range(Width):
for iH in range(Height):
pixel=System.Drawing.Bitmap.GetPixel(bitmap,iW,iH)
RGB = (255, pixel.G, pixel.B)
color = rs.CreateColor(RGB)
System.Drawing.Bitmap.SetPixel(bitmapNew, iW,iH, color)
Is there anything I can easily do to speed this up?
I did some optimization without the bitlocking Dale suggested. I think that will be even faster but I have no time to check that out.
What I did was create a new color directly from the pixelcolor.
640 x 407 pixels. Total = 260480
JH_version : 8.17264556885
WD_version : 2.88730621338
import System
import time
def JH_version():
def WD_version():
color = pixel.FromArgb(255,pixel.G, pixel.B)
bitmapNew.SetPixel(iW,iH, color)
#bitmapNew.Save('C:\\test.jpg')
def main():
stime = time.time()
JH_version()
print 'JH_version time : {}'.format( time.time() - stime )
stime = time.time()
WD_version()
print 'WD_version time : {}'.format( time.time() - stime )
main()
