Hello, need modelling help for 3d printer result
Hello, new here but looking to learn.
Im making a mixed model of solids and surfaces for 3d printing.
But when importing the resulting stl in the 3dprinter software it gets some zones not solid, like missing pieces of the mesh specially for the middle part which is made as a surface.
Im looking for help making it a solid model, like joining the middle part to the sides so it gets recognized as a manifold model by the 3d printing software.
So far this is the file i have managed to create:
hoping someone can give a hand or enlight, thanks.
Yuor google link requires authorization to be opened.
To better help you should share the file directly by uploading it here (eventually as Zip file) and upload a couple of screenshots of what you’re wokring on.
This help people to understand better the context and suggest the optimal solution.
Hi skysurfer, thanks for the response.
Im attaching the file.
rascador c.zip (282.5 KB)
I need to make a solid piece of the surfaces with the rest.
in creality slicer the surface parts dont print correctly
I’m checking your file and I found that the central part isn’t a solid nor even close:
This happen when you use the Patch command to fit around multiple curves that not create a rectangular grid.
The fix could be simple or complex depending on the result you want to achieve. For a prototype 3D print it would be enough to extend both surfaces and find a clean intersection.
  1. _Untrim the two patch surfaces
  2. _ExtendSrf the side surface
  3. _Trim them togheter and _Join them into a solid
now the central part is solid and can print.
To improve your drawing you should make the side structure slightly overlap the central core so the printer can print it bondend togheter.
this is my file with the 3 illustrated step
rascador_RG.3dm (534.6 KB)
Thank you skysurfer will take a look at it asap
As a general rule in NURBS modeling, try to avoid creating of tight rounded corners. Instead, build the geometry in a more simple way and add small fillet or blend corners later. The other benefit of this approach is that it lets you build far simpler primary surfaces that are smoother and easier to modify to achieve the desired shape.
In your case, this means to create 6 individual surfaces where each pair meets at a sharp corner. If needed, you can add fillets later.
