Heightfield Resolution Issues in GH (File Attached)
Hello!
I’m trying to create high quality mesh heightfield data using GH. The unusual thing is that I get a noticeable grid imposed on the heightfield result.
If you adjust mesh density, the grid adjusts too, so it’s not based on the image data.
I actually get similar problems with Rhino’s native heightfield command.
Does anyone know if there is a way to solve this issue?
Thanks for your time!
Heightfield_Test_Forum01.gh (1.3 MB)
the image you are sampling has size 1080 px by 1080 px, so I guess setting the mesh size to 1079 will produce a grid with 1080 samples per side, which means each pixel color will be sampled once? I don’t see issues in that case
Heightfield_Test_Forum01_inno.gh (1.3 MB)
@inno Good thinking! Thank you!
