I am frequently using the “_Heightfield” command (in vb script) where I define more than 10.000 control points for the surface creation. As a result a warning dialog is displayed:
“The resulting surface will have 40000 control points… You might run out of memory and crash. Do you want to save your model before proceeding?”, urging me to save the file.
Is there any way to suppress this dialog, i.e. disable the alert? It makes no difference if “_Save” was used before the command.
Thanks.
