Hi all,
I’m trying to make a heat map based on tenant performance data using Elefront.
However the color result for each tenant boundary after bake in Elefront does not match with list of RGB in order. Please see the image below.
For example, the RGB for Tenant #9 is (255, 208, 0) in the list but the outcome is Green.
Any advice to break through this problem would be appreciated.
You can refer to the attachment.
Heat Map Coloring.zip (750.3 KB)
Thank you in advance.
SB
