Looks good! What method did you use to generate these geometries?
Thanks
I used Grasshopper in combination with Millipede, Crystallon and Pufferfish!
I have been using millipede to generate TPMS meshes but find they are often of bad quality and mesh splits / mesh intersections often fail.
Have you experienced any similar issues / found any solutions?
I would love to see you script if that’s something you would not mind!
Andy
Forgot to mention that i used the Dendro Plugin for the mesh thickening
You can also make some heat exchange with the technique described here
