Trying to run Rhino as a child process in a script, is it possible to run Rhino without showing it’s UI?
If not, is there any way to trigger a command from the parent process ?
Hello - not sure if this is of interest -
Also, check Rhino.Inside samples: https://github.com/mcneel/rhino.inside/
There are discussions in https://discourse.mcneel.com/c/serengeti/inside
If you’d like, we can move this discussion there…
Thanks, completely forgot about that one… Remembered only the Compute version.
Thanks.
