I am having a bit of a problem with ‘sweep2’. I have tried to prepare the two rail curves as meticulously as I can, using ‘setpt’ to force all curve points to the required height. Zero for bottom rail, and 10 for the top. When I ‘sweep2’ and attempt to cap the resulting polysurface, only the bottom is capped. Error is ‘one attempted object is still open’. Now, I only actually want the bottom to be capped, but I need to know that the top is planar so that I can mirror, extrude it, etc. If I carry on as it is now, I end up with gaps between surfaces. Can anyone tell me how I can track down where the problem is? I suspect sweep2 has altered the position of some points but perhaps something else. Also, how do I ensure that the exact height between the rails is actually maintained? Do I need more sweep objects (lines in this case)? With this surface it should be exactly 10mm all round.
Thanks,
Alan
sweep issue surface.3dm (501.5 KB)
