I have a simple object ( a round tube ) and it is not perfectly lined up on my X,Y,Z axis. So for example if I put a point on the center of both ends of the tube and then move the object so that one of the center points on the end of the tube is at the location 0,0,0 and then if I look at the location of the other point on the other end of the tube it will be off a very small amount ( in fact it’s so small that it won’t display the exact coordinate because the decimal point would be so extended out )
Is there a command in Rhino that can be used to level an object so that its perfectly strait on the x/y/0 axis?
