Having Problem Culling a group of geometries from a slat Panel
So I have a created a series of slats. I created a shelf condition and I want the slats that are in this area. I first created a box and isolate those peices with an intersect boolean and then add those pieces wth the overall. I was able to see that these items have been repeated as 2 elements in a branch. However I cannot remove those branches. I hope this isn’t confusing, I’m trying to find ways of removing items from the shelf condition. Hopefully this makes sense.
041324 - Cull Item.gh (87.8 KB)
missing
an easier way to do that, if I have understood your question correctly, is to filter items based on their Volume Centroid
because items to be culled are fully contained by the box you have drawn, then for sure also the Volume Centroid of the items to be culled are fully contained by that same box
you will find the geometries outside of the box in Dispatch → B output, and the ones inside the box in A output
041324 - Cull Item_Re.gh (94.3 KB)
Thanks so much Inno!
