Hello, I need help with applying lunchbox pattern on multiple surface. Before asking this question, I also want to figure out why the loft result comes out differently in grasshopper.I attached two images below with two results. The ultimate result I want is to apply these triangular pattern on this loft surface,which will wrap around the whole surface area. Because I coundn’t solve these two issues, I ended up applying these pattern on a flat surface first, then project them back to the doubly curve surface. However, this will not be a perfect solution for what I want.
thank you for solving my first question! For my previous model, I used the Triangular Panels A in lunchbox, but for now, I think which pattern doesn’t really matter that much. I just want to figure out the way to apply pattern on multiple surface.
Problem Solved! Just one more question, what does the toggle do that connect the interpolate? I found out it does not really affect the result of recreated curves, but it will affect the result of loft surface.
