Having multiple numbers in a single objectives
Hello Wallacei developers,
Is it possible to have multiple numbers in one objective?
I saw on youtube that it is possible but coudlnt figure out how it affects my objective and on the phenotypes,
Tnx in advance,
Tal.
Yes, you can have multiple objectives (numbers) in one Number Parameter component (make sure to flatten it). However all the objectives in one number parameter will be treated as independent objectives in the simulation. The only difference between them having in separate Number Parameters is that they all inherit the same name (numbered) as the Number Parameter component that is holding them.
So the only difference between having multiple objectives in one Number Parameter component and having them in separate ones is their names, it does not have any effect in the optimisation and both scenarios are the same in optimisation scenario.
Thank you very much for the quick reply! :slight_smile:
