Have two units
Is it possible to have two units when I measure a length.
A unit has example from 1/1 = 100 cm and on the same line the value of the scale unit 1/20 = 5 cm ?
The idea is to build a model of my project and don’t loose time to calculate each measure one by one.
Thanks a lot
Thierry
You could create a scaled version of your Rhino model. Copy the model, select it and use the Scale command.
Hi Thierry - this seems like the perfect opportunity to do some scripting.
Looking deeply in Rhino I found the solution.
In the properties of the dimension you have a tab to add an alternate unit :slight_smile:
And there you can add a second unit on the same dimension line with another unit or scale.
