it returns None. The solid hatchpattern exists in the file, once i open the _Options dialog, click on the Hatch page entry and close the _Options dialog, then run the script again, it returns:
HatchPattern: Solid (0)
I can repeat the same behavior using the now obsolete method:
What you have observed is true. Rhino doesn’t populate the Hatch table until you do something related to hatching. This is to keep the 3dm file small and efficient.
In Rhino 6, the Solid hatch pattern is hard-wired to a index of -1. So you can always retrieve it if needed.
index = sc.doc.HatchPatterns.CurrentHatchPatternIndex
print index
name = sc.doc.HatchPatterns[index].Name
print name
i see that i can get and verify the Solid hatchpattern in V6 like this:
solid_index = -1
solid_pattern = scriptcontext.doc.HatchPatterns.Item[solid_index]
if solid_pattern.Name != "Solid":
print "SOLID NOT FOUND"
return
But i still cannot get a hatch created. This is my code:
hatches = Rhino.Geometry.Hatch.Create(curves, solid_index, 0.0, 1.0)
print hatches
for hatch in list(hatches):
print scriptcontext.doc.Objects.AddHatch(hatch)
and this is the output:
Array[Hatch]((<Rhino.Geometry.Hatch object at 0x00000000000000A3 …
00000000-0000-0000-0000-000000000000
Is there a reason why -1 is used as the default index ? I mean in the past decade this has always been a number reserved for “not found”, imho it is slightly confusing.
The reason why i try to create a hatch is btw. that i cannot get text entities to work properly in V6 using a custom font. If i add that text entity to the document, the name dropdown in the properties for Font remains empty and to my surprise a new dimension style is created with the name of the custom font. Somehow this dimension style is then used as default. If i then create a new dimension, all dimensions use that as style. Is this expected ?
I’ve been using the new Rhino.Geometry.Hatch.Create method which has a tolerance argument as shown here. For the hatch pattern index i’ve used -1. The hatches are returned from the method, however if i try to add it to the doc, i only get an invalid id. The curve is reported as closed, creating a _Hatch from it in Rhino using the GUI works, but not via code.
