Hatchings - Label square meters
Hello everyone, I have a question for you. I need to write the square meters of the hatches in several floors. Can you possibly be helpful for a Grasshopper definition? I know myself there unfortunately still too little. I would be very grateful to you!
Many greetings
Boris
Hi Boris -
Without rather detailed specifications and a file with geometry, it’s extremely likely that any help you get here won’t do what you want and ends up being a waste of time for the person trying to help you…
Hi Wim, I would like the yellow marked area to be labeled with the square meters. xx.xx m2 = 25.04m2
Many greetings
Boris
do you only have hatches, or you also do have the original curves inside of which the hatches were done?
Hi Inno, it’s just a matter of having a square footage (m2) at all the individual hatches.
Maybe the automatic translation from German to English has a little trouble :slight_smile:
Many greetings
Boris
if Elefront plugin is an option, this can be a solution:
Elefront_area_on_hatch.gh (8.6 KB)
edit: added format to add “m2” and account for 2 decimals:
Elefront_formatted_area_on_hatch.gh (9.3 KB)
Hello Inno, thank you very much I will be happy to try it.
Many greetings
Boris
