Hatches rhino
Is it possible to change hatch in rhino when hatch polyline is changed?
(No scripting just typical drawing procedure) When I change boundary poly-line I have to redo hatch again.
If this option is not possible would it be possible to include this option in rhino 6 ? :))
You can do a bit of adjustment by using curve control points. It’s not perfect but you it works for a fair number of instances. There may well be a better way that I’m unaware of though.
This should work in V5 already if you have History enabled, and you modify the hatch boundary non-destructively (i.e. point editing for example - but no trimming, splitting or deleting of parts or anything else that would destroy the object’s GUID)
–Mitch
Hi Mitch
Thanks with history enabled works perfectly.
