Hatches Do Not Change Layers After Initiating Hatch Command in Rhino 9
I frequently use the Hatch command in Rhino 7 and have grown to appreciate that, after initiating Hatch (when the Hatch window pops-up), I can change my selected layer and the both the preview hatch and output instantly change.
This behaviour is different in Rhino 9 and while I can still change my selected layer with the Hatch window present, neither the preview nor the output hatches are changed to the newly selected layer.
What this means for me is that I either need to ensure I have selected the correct layer before running Hatch every time, or I have to manually select all of the hatches afterwards and manually change the object layer which adds several steps and a great deal of headache compared to Rhino 7 where I can change layers on-the-fly.
Is this a bug? If not, can this be reverted in Rhino 9 to behave like Rhino 7?
Thank you
Hi @Zane_Parkinson,
Rhino 9 behaves this way since Rhino 8. The Hatch command picks up the current layer when it starts, so changing layers while the Hatch dialog is open doesn’t move the preview or the resulting hatches.
Until then, the quickest way to put a batch of new hatches on a different layer is:
  1. Run Hatch as usual and finish the command.
  2. Run SelLast to select the hatches that were just created.
  3. Run ChangeLayer (or use the layer field in the Properties panel) and pick the layer you want.
You can also put ! _SelLast _ChangeLayer on a toolbar button or alias to make that a single click after hatching.
I don’t know how hard it is to bring back the V7 behavior - @Trav might have an idea.
– Dale
