Hatch Worked in Previous Version of Rhino But Not Now
The attached file contains a closed curve that I created in some previous version of Rhino. The HATCH command worked with it back then. Now Rhino says there is a self intersecting curve.
I have included a hatch that was made from some previous version of Rhino.
What happens when you dig out olde files and try to work with them again. :frowning:
Problem Hatch.3dm.zip (27.1 KB)
Thank you for your report, and this is a known issue to be improved.
You can create the hatch with Grasshopper, fyi.
Hatch.gh (7.9 KB)
Hatch
RH-87080 is fixed in Rhino BETA
