Hatching works fine but when I select a hatch and try to change the scale in hatch properties it moves to pattern scale 360.
It looks like this is a maximum cause I can edit it to a scale lower than 360 but can’t scale it up.
Also when I try to use the match command it doesn’t match a hatch with a pattern scale higher than 360.
Ties
