Good afternoon, I have several questions about Shape Diver.
There is no ability to transform the “pattern hatch” component into the Shape Diver component? only solid and gradient fills are supported? When this feature will be added to Shape Diver’s plugin?
Thank you!
Rhino hatch patterns are not supported but you have following options:
- You can recreate them either as curves in Grasshopper but this might be computationally heavy depending on complexity of the pattern.
- Or you can recreate the patterns as texture bitmaps instead. This is definitely better for performance of your models, just make sure you keep the textures around 1MB. Read more about texturing in this article:
If you have any feature requests or suggestions on how to make ShapeDiver even better, let us know:
