Hatch "Match" doesn't match color
  • Make 2 rectangles
  • Call Hatch, select one rectangle, choose Solid and pick Red as a color and OK
  • Select the other rectangle and run Hatch, also solid. The color will be the previous one (red) by default, change it to black and OK
  • Now delete the black hatch you just made
  • Call Hatch again and select the second rectangle again, the default will be solid and black - then press the match button at the bottom of the dialog
  • Choose the first (red) hatch you made as the match target and OK. The second hatch will not be red, it will remain black.
