Hatch Issue. the viewport window relocates to 0,0,0,
I tend to hatch in Layout/Paper space. This doesnt happen all the time, but happens more often than not. Process; CMD Line-Hatch, I select the Closed Curve to hatch, the hatch is applied, and as soon as i hit enter the viewport relocates to 0,0,0, in model space. To correct this i need to go into model space and locate the curve i just hatched and move it back to where i just hatched it.
Hello - thanks, I’ll see if I can reproduce this - if you have a blow by blow to reproduce, or an example file, that would be helpful.
Thanks Pascal, I recorded it.
t
I see… thanks.Hmmm - so all the input curves to the hatch are on the layout, it looks like, correct? Does locking the detail do anything helpful for now?
@bournedesign I am gettng your file (thanks) but please keep in mind this is a public forum - you may want to edit yourt post to remove that link.
When in doubt, send to tech@mcneel.com, with a link back to the Discourse topic in your comments.
Hi Tristan -
So far, I’m not able to reproduce that behavior here.
Could you run the Rhino SystemInfo command and copy-paste the result here?
Rhino 7 SR18 2022-5-4 (Rhino 7, 7.18.22124.03001, Git hash:master @ b2a1120bcb32e1f6da66a421cd7162a18a9f0cd9)
License type: Commercial, build 2022-05-04
License details: Cloud Zoo
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display and OpenGL: NVIDIA Quadro P3200 (NVidia) Memory: 6GB, Driver date: 1-28-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.65
- Secondary monitor attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-28-2022
Driver Version: 30.0.15.1165
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\MeshCommands.rhp “MeshCommands” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Import_PDF.rhp “PDFReader”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.18.22124.3001
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
