Hatch is overlayed with other hatch?
Hi fellow Rhino users,
My hatch is overlayed with other hatches and I can’t seem for it to with both hatches
on picture 1 and 2? Could someone tell me how to correct this?
TIA!
First, the order is dependent on the layer order, next, see if any of these commands help:
SendToBack
SendBackward
BringToFront
BringForward
Actually draw order should be, but is not, layer order dependent right now…
Hmm I assumed so, because there was no way I could make it work otherwise. Was this fixed in rhino 8 maybe, because there I was using it.
Hi Gijs - I do not see it in V8 WIP either, here.
Ah, I now think what caused me to think this. It appears that the layer order does have a bit of influence. In my case I drew a new object (hatch) over everything in the scene and expected the new object to be on top, but it’s only on top of some, But then when I put the object in the top layer, a lot more objects were hidden behind it.
Interesting - I will test… just out of curiosity; I am pretty sure I understood from the developers that this is not working, at least not correctly, yet, for whatever reason.
indeed not correctly, but it does have an effect, see this:
Hm - if you are changing the hatch’s layer, that moves it to the top of the object stack in the document as well, so that may also come into play.
but that would mean after I move it from the red to the blue layer, it should be on top of everything else. That’s what I did. Here’s the file if you want to have a look:
vector-icons.3dm (347.0 KB)
Yeah, notice I hedged with ‘come into play’ and not ‘do something predictable’…
:grimacing:
But if the hatch is actually in front in 3d, the draw order is the same regardless of the layer. I guess fighting at the same Z is yet another factor…
