I found a display issue in Rhino 8 when using BlockEdit.
I have two separate blocks, each containing regular geometry and a solid hatch. All object and hatch colors are set to By Layer.
When I edit Block B, the solid hatch inside Block A turns black. The other geometry inside Block A keeps its normal display.
The important part is that this only happens when the hatch is inside another block.
A hatch with the same layer/color that is not inside a block keeps its correct color during BlockEdit.
In the attached screenshot:
- Block A: not being edited → hatch turns black
- Block B: currently being edited → hatch stays red
- No Block: hatch outside any block → stays red
The same behavior also occurs with BlockEditNew, so it seems to be related to Rhino’s display handling of hatches inside locked block instances rather than the plugin.
This issue is especially problematic in my workflow because I regularly use hatches as part of block definitions. During block editing, the hatches in other blocks no longer display with their actual layer colors, which makes visual coordination and checking between blocks difficult.
Is this a known Rhino 8 display bug, or is there a setting that controls this behavior?
SystemInfo
Rhino 8 SR33 2026-7-7 (Rhino 8, 8.33.26188.13001, Git hash:master @ 482f88a83547c62cde64d78ea8a8690b7349f289)
License type: Educational, build 2026-07-07
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 64GB)
.NET 8.0.23
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5080 (NVidia) Memory: 16GB, Driver date: 1-20-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.86
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.6 (primary GPU's maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-20-2026
Driver Version: 32.0.15.9186
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp "V-Ray for Rhino"
C:\Users\sveng\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp "D5 Live Sync for Rhino"
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp "Datasmith Exporter" 5.6.1.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp "VisualARQ"
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp "Tibidabo"
C:\Users\sveng\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\BlockEditNew\2.1.7\blockeditnew.rhp "BlockEditNew" 2.0.0.0
C:\Users\sveng\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\jifto\1.2.0\net8.0-windows\jifto.rhp "jifto" 1.2.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp "Commands" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp "WebBrowser"
C:\Program Files\Rhino 8\Plug-ins\rdk.rhp "Renderer Development Kit"
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp "RhinoScript"
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp "IdleProcessor"
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp "Rhino Render" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp "Legacy Rhino Render"
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp "RDK_EtoUI" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\NamedSnapshots.rhp "Snapshots"
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp "MeshCommands" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp "IronPython" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp "RhinoCycles" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp "Grasshopper" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp "Toolbars" 8.33.26188.13001
C:\Program Files\Rhino 8\Plug-ins\3dxrhino.rhp "3Dconnexion 3D Mouse"
C:\Program Files\Rhino 8\Plug-ins\Displacement.rhp "Displacement"
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools"
