Hi Rhino 9 development team,
Can you make Ctrl+Shift+Click select a sub segment of a hatch boundary just like it works for a surface boundary?
thank you!
I used the most recent Rhino beta and this seems to work. Can you update to the most recent build and see if you can also get it to work?
Hi @scottd ,
I updated to the latest beta 9.0.26202.12303, 2026-07-21
Ctrl+Shift+Click to select a sub segment doesn’t work for hatches and for surfaces that resulted from hatches (from explode).
In the video i am trying to select a subsegment of a hatch, of a surface resulted from a hatch and of a surface created with the surface tool.
Yeah, I see what you are getting now. Before I was using history to edit the original boundary.
WE will see what is possible when we look at this.
This looks related to this recently filed issued
no, it’s a different issue, because i deleted the rectangle right after i created the hatch.
You’re right, changing to top view does not help (unlike the previous issue). The youtracks have been marked as related just in case.
