Attached are two screenshots, one of the actual sheet layout in Rhino and one of the pdf. For some reason, in Rhino, the hatch appears below the lines as it should - but after printing (both to pdf and directly to a printer) the hatch appears to cover the lines.
We have tried all of the send to back, bring to front, and clear draw order commands - and have also tried printing using different drivers (Adobe, Bluebeam, and Rhino) and as mentioned, this also happens when sending directly to a printer. We also tried placing the hatch layer at the bottom of the layer list.
One thing to note: the linework is a linked rhino file into our sheet file - using “linked” and “active” options.
Any thoughts on how to get the linework correct?
Thanks
View in Rhino:
View in PDF (or Print):
