Hatch. Control Points. Control Polygon doesn't highlight. (Bug?)
If the Hatch has a hole inside, then the control polygon from the selected point on this hole is not highlighted.
But control polygon inside the hole selected only next point from the start point.
2023-03-10_13-42-51
Highlighted outside only.
But in some complex Hatches if select the point outside, then the inside control polygon of hole are randomly highlighted.
Hatch_complex
Hatch.3dm (537.8 KB)
I’ve been watching this behavior for a long time.
Seems from the v4.
I just used this tools.
So now I’m not sitting down and wrote above. :slight_smile:
Hi -
Thanks, I’ve put this on the list as RH-73556 Display: Selected control polygon of hatch
RH-73556 is fixed in the latest WIP
So fast :slight_smile:
Thanks.
Believe me, it doesn’t always work out that way.
