@pascal, i guess i’ve found out what caused the problem discussed here, if a _Hatch
with history enabled is created eg. in Front or Right viewports, it fails to update. (V5 and V6)
c.
c.
Just to add my findings on this one…
Model: rectangle on the XZ (Front) CPlane and a history-enabled hatch.
When selecting the rectangle and then moving it, the command line echoes:
Command: _Move
Point to move from ( Vertical=No ):
Point to move to <330.00>:
History updated 1 object.
The “Move” command created 1 bad objects.
That means that history does update the hatch but it gets squashed into a bad object. Depending on what hatch was used, you can or cannot see traces of it in the viewport.
RH-38726 is fixed in the latest WIP
