Has RemoveExistingSymmetry been implemented yet?
Hello all:
I was experimenting with Reflect SubD Object today, and I noticed that while the command RemoveExistingSymmetry is mentioned in the help file for Reflect, but the command is nowhere to be found in Rhino 7’s menus or Command: prompt type-in.
I assume it’s the way of turning off symmetry.
Has it been implemented yet?
Regards,
Jack
Click on it, it’s not a bomb, you get the result.
Never mind. I couldn’t find the option before, but I found it now. It’s an option inside the Reflect SubD Object Command.
No need to be rude. Thank you.
He wasn’t rude.
He was poking fun at you in the mildest way.
Grow up. (if that doesn’t sound rude to you)
