HARSH SHADOW LINES / printing help
hi there,
is there any way to remove the harsh shadow lines???
also, I would love some help troubleshooting this printing issue? yesterday it was fine, I haven’t changed any of the print settings, so not sure why the shadows in arctic aren’t coming up here.
Thanks,
Zoë
Hi Zoë -
Please provide a .3dm file. It’s close to impossible to troubleshoot issues from screenshots.
BEDROOM CORNICE, DADO & SURROUND_DTL 34_rhino forum help.pdf (5.3 MB)
hi Wim, unfortunately my file size is too large to upload on here, I hope this pdf / screenshot might help further?
My viewports are on artic with the surface lines switched on - but on this document, it seems to come up at different thickness too… not sure why the change happened.
can you help?
Hi Zoe -
I’m afraid not. A simple 3dm file would at least tell me if you are using Rhino 4 or Rhino 8…
Please run the Rhino SystemInfo command and copy-paste the output here.
Please upload the 3dm file from Rhino Accounts. Make sure to add a link to this thread in the comments field.
Thanks,
I guess the problem is the lines I highlighted in the green rectangle?
Yes, exactly that! And the thick dark lines around the middle wall - they should be the same as thickness as the other lines.
It could potentially be printing at too high a DPI. I’ve been having this same issue, but lowered the DPI of my print and they disappeared
