Hi, I’m making a service using Rhino Compute based code,
which receives input data via api and compute gh file using input data, returns output geometry data.
My service runs on AWS instance (system info is attached below).
However, it is quite slow, so I’m considering scaling up instance spec.
My question is:
- Is Graphic card needed for Rhino Compute service(It works only as an api server, no need rendering)??
- Do I need to apply some kind of option command to disable rendering?(which is unnecessary since Rhino compute server do not need any visible output) If it is, is there any rhino command I can use??
I was just wondering If there is some performance optimization skills/tips for rhino compute based service. - What is critical reason of bad performance from my current spec / and what is recommneded spec?
Intel Xeon Platinum 8175M CPU @ 2.5GHz
Windows 10.0 SR0.0 (Server) or greater (Physical RAM: 3.9Gb)
Machine name: EC2AMAZ-1K110CA
Non-hybrid graphics.
Secondary graphics devices.
Microsoft Basic Display Adapter (Unknown) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: (null)
Driver Version: (null)
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: n/a
Rhino plugins
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands” 7.0.19233.6455
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.0.19233.6455
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.0.19233.6455
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.0.19233.6455
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.0.19233.6455
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
