Hello there. Im quite new to Kangaroo, trying to create hanging pendant light kinda thing. So, I want to use stratchy cloth base and a metal pipe, hanging on it forming it with its own weight.
How can I simulate this?
KHStr.gh (19.3 KB)
This should get you going:
KHStr-rev.gh (21.6 KB)
Your base mesh was invalid. Iâve included another way by starting with half a mesh sphere.
Thank you for your time! That is not qite what i wanted. I wanted the mesh to be stretched under the weight of the metal ring attached to it. But thanks again
I have no idea what Kangaroo is doing but fixed your input mesh using a Cone (white group). The output, however, is still an âInvalid Meshâ?
âFactorâ slider for Z Move changed from -19 to +30:
Kangaroo has a Combine and Clean component which in this case turns the invalid mesh into a valid meshâŚ
I canât make it work. Kangaroo is so complicated and mysterious⌠OH! You put Combine&Clean at the beginning, after Mesh UV (Mesh Surface). When I do that, the mesh always sags below the ring, no matter where itâs positioned in âZâ. Valid mesh output but not good!
P.S. There is one point âanchoredâ?
KHStr_2022Sep27b.gh (20.7 KB)
Aha! That one anchored point needs to be at the top of the cone, eh? Combine&Clean must have modified the point list, so I sorted them by âZâ. Works now.
