I am facing this issue whereby the handles of the default door style appears partially embedded in the door. When I copy the doors to a new file, the handles show up fine.
@Julius3 if you run the vaUpdate command on the door that has the handle partially inside the leaf, does it restore the handle position correctly? if it doesn’t please share that file and I’ll take a look.
Does that happen in any other file?
The vaUpdate command does not restore the handle position.
Door_Handle_Issue.3dm (455.6 KB)
If I copy the same door to a new file, the handle returns to the proper position.
Hi @Julius3 I think this issue happens in documents in millimeters only. We will fix it in one of the next releases.
@Julius3 this error with the handle position has been fixed in the official release of VisualARQ 3.
